Staging question for all of the pro's here
Username: Avalanche
Post Number: 78
OK here is the deal. I am starting my build on a Chevrolet Avalanche. Tomorrow.
Question 1.
What is your opinions on putting a 6.5 plus a 8 inch mid in the stock factory door for staging.
The door will be completely Dynamated with Xtreme.
Speakers are Diamond audio M661 and Kicker RMB8.
Here are the specs.
M661
General
Type: Component
Drivers: Tweeter, Midbass
Drivers per Channel: 2
Woofer Cone: Titanium-Magnesium
Tweeter Cone: Silk
Tweeter Mounting: Flush, Surface, Angle
Specifications
Power Range (watts): 20-170
Imped (ohms): 4
Crossover Included: Y
Sensitivity with w/2.83-V input @ 1 meter (dB SPL): 91
Freq. Response (±3dB): 46Hz-24KHz
Dimensions
Mount Depth: 2-1/8"
Diameter: 6-1/2"
Tweeter Dia: 1"
MODEL RMB 8
Frequency 30-500
Power 350 / 175 RMS
Cut Out 7 1/4 / 18.42
Mounting Depth 2 1/4 / 5.8
Sensitivity 89
What is your opinion on this set up and location. Now acouple of things to remember are the midbass RMB8 are free air. and the door on this truck has the new L shape design for the factory speaker. I am curiouse on your thoughts on this before I begin.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6949
deja vu
Username: Avalanche
Post Number: 80
Yes because I am finally starting on the truck
