Ok I got it
I got 2 12" Fusion PowerPlant's in my Chevy Xtreme ran by a Clif Designs 2400watt amp! But I dont know what kind of enclosure to use to get the hardest hitting and I dont know if I need to change my alternator cap or anything like that! And is it ok to run an extra 150watts to a sub! lIke my Fusions are 450rms and my amp is 600rms? is this ok? Need any help!
Username: Swantlaphoenix
Tucson, AZ
Post Number: 24
I dont know much about those subs but running it higher should be fine if you think they can handle it. Make sure you have the gains set right! You most likly will need something extra like a cap or H.O. Alt with a 2400 W amp. All I could suggest is run them and see how it preforms. See if the lights dim or anything else at that
