Opinions on the loudest subs to run on this amp?
C19958
I have a Rockford Fosgate 1001bd amp (1000 watts x 1 at 2 ohms, Not stable any lower) What is the loudest possible sub/s that i could run with this amp. Space isn't really too much of an issue. I'm open to any ideas. I don't really care about the number of subs eigther, i just want something really loud that has a small amount of SQ. Thanks for everyones help
JayB901
I would say brahma 15 or X.X.X 15 but i think that are both dual 2 ohm subs, so you can only wire them to 4 ohms with that amp because it is not 1 ohm stable. Check with someone else on this board, they may know
I would say go with a X.X.X 15 or a brahma 15, but they are both dual 2 ohm subs so you can't fire them to a 2 ohm load. Check with some others on this site they may know a better sub for your amp, or you could try a system like (2) 15" Treo SSi's or some other pair of dual 2 ohm subs.
my bad about posting twice
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 117
get the dual 1 version. And the nwire it in series. and youll get a 2 ohm load
