Component System With Or Without Amp?
Mwahaha
Do Components sound bad without an amp connected? I'm thinking about buying infinity components for the front. Will they sound better then just buying two infinity 6.5" speakers for the front. How will the components sound in comparison? Keep in mind I don't have an amp.
Username: Langless28
Post Number: 64
infinity comps are power hungry i run mine round 60watts and they sound great. im assuming u mean running them off the hu. as long as it puts out 20 watts i think it should be ok. i would reccoment getting an amp tho
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6950
you can run em off the head unit, sure.
will they sound better with an amp? definitely.
not just louder, but fuller, and warmer. it takes power to get the midbass moving.. but you'll surely be able to use them from a head unit, yes.
