Hey Glass?
Username: James1115
Ct
Post Number: 80
OK now I am between a Adire Brahma 15,a eclipse TI 15, and a REXXX 15 what would sound the best with 600rms and what size box shuold it be in. I listen to rock/country/and a little bit of rap. I know you said the brahma will reach its max output with 600 rms now will the RE as well? what do you recomend for me. I have the space to put in a sealed or ported box so I appreciate your input.
James
Username: James1115
Ct
Post Number: 81
ohh yeah and it has to be a dual 2ohm driver. or single 4ohm but would preffer dual 2ohm.
thanks
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6926
the Ti and triple X need more power.
the brahma is your sub.
3cu ft ported should do the trick.
go slot vented if you can and have the room. remember the slot vent and sub displacements need to be subtracted to get the net volume for the enclosure.
