I need some help building a box.
Username: Yoy0master
I'm buying a 15 inch diamond CM3 sub and would like to know a recomended sub box design (like depth, width maybe even a diagram) so my dad can help me build it. Thanks very much,
Andrew
Username: Koz1031
Monticello, In United states
Post Number: 341
check their website and see what they recommend. Most ususally do. If not you will have to deside what type of box you want. sealed,ported. and how big you will want it. after that it's pretty elementary.
Username: Eric77
Post Number: 61
go to www.diamondaudio.com then email their tech support and ask for box plans for a ported 15" cm3. They should have something.
