Bronze Member Username: FordpwrLos angeles, Ca Usa Post Number: 41 Registered: Dec-04 | does anyone know the measurements of a good box for a 15" x.x.x.-ported.what about the design,shape.etc.etc. i checked the RE website but they don't give you mesurements and those guys are hard to get a hold of.oh, i plan to build the box myself by the way and i'll be poWering the sub with a HIFONICS 1500. SUB IS A DUAL 4 OHM--------THANKS |
Bronze Member Username: JdcPost Number: 44 Registered: Oct-04 | dont they come with the mesurements on the papers in the box you buy it in. |
Silver Member Username: JmloughreyFarmington, CT Post Number: 641 Registered: Jul-04 | yahoo search a program WinISD, its a sub box building program, it'll allow you to put in the parameters of the sub (all available from the sheet that comes with the sub as well as the RE website.) |
Bronze Member Username: FordpwrLos angeles, Ca Usa Post Number: 42 Registered: Dec-04 | thanks-reason i asked was because i havent received it yet THANKS AGAIN |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6872 Registered: Dec-03 | WinISD will help you a lot. also refer to www.bcae1.com for helpful info in box building |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6873 Registered: Dec-03 | also www.jlaudio.com under "tutorials" and www.teamrocs.com under their audio and technical FAQ pages |
