Recommendation for front speakers
Username: Zepp
I replaced my factory rears with infinity reference 6002i 2-way speakers, but now I need to replace the front ones. I know that the front is more important than the rear. My car isnt setup for component systems, but I suppose a little bit of modification to the panels will allow for components. Either way, would you suggest for up front? My budget is $150 for the pair. Thanks
Username: Kklagge
Post Number: 30
If you have some room between the door panel and the speaker you could go for some CDT braxials where the tweeter is mounted on the frame of the woofer.
Username: Zepp
Post Number: 7
while they do look good, they are a bit out of my price range :-)
any others?
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 308
Boston Acoustic has the same type of set up on their rally and pro series. They have very good SQ and might be closer to your price range.
