Which part of my system should i upgrade first.....
hey guys,
I want to upgrade my car's stock system, but i dont hav all the money now. I've decided to upgrade part now and part later on when i hav some more cash.
I was wondering what part of my system should i upgrade first, should i put in the HU, sub and sub amp first and later on do the components, midbasses and comp. amp or vice versa.
head unit front speakers rear speakers 4 channel amp for the speakers sub amp sub(s)
that gives you a listenable system all the way through the process, with the most noticeable changes as you go.
Ok thanks for the advice glass, i'd go with ur suggestion.
For those components and midbass speakers, what kind of amp would u suggest. The ting is, adire says the rms ratings are only thermal, so how would i know how much juice is enough.
the koda comps will do great with about 50 watts per channel. maybe 75 at most. the midbass drivers I'd give 50-100 watts each depending on where you put them, etc.. re'q power varies but its usually around 80% of thermal RMS handling or so.. ballpark
Ok Thanks for everyting glass, you've been a great help. I'll post another thread in the future and tell u how the system came together. Thanks again.
