Devon Unregistered guest | box for 2002 chevy silverado ext cab would there be enough room to fit 3 down firing 10" subs under the back seat? |
Silver Member Username: JmloughreyFarmington, CT Post Number: 629 Registered: Jul-04 | dont know how much room you have....measure it out, figure out what you have space wise, section it off for the subs, build, enjoy.... www.bcae1.com will tell you all you need to know about sub box building |
Devon Unregistered guest | 13"x9"x58"...with the hump in middle 5"x12" |
taylor17 Unregistered guest | Just wondering why are you downfireing the subs. I have a 98 chevy extended cab and I have 2 10's facing normal. The only problum you will have is you want 3 of them I am not sure but 3 should fit, you could put 2 on one side of the hump and 1 on the other side, or you could put 1 on each side and where the hump is you could just make the box a little biger for the lack of highth. |
Devon Unregistered guest | well i was also thinking take the back seat out i would have more room for more stuff. |
Devon Unregistered guest | or the guy at benchmark(local car audio place) said he could make me a center console that goes from dash to front of back seat and put 3 10's in it |
