JL 1000/1 and 2 Shivas
Username: Its_bacon12
Post Number: 108
this thought crossed my mind if i got 2 jl 1000/1 amps and 4 Shivas would that be better than getting 2 12 inch brahmas? im not sure, i know im gonig to go with one of the two choices for my next setup.....or should i consider w 12w7's? money will not be a factor this time like it was last time with that audiobahn lol soooo....i definately want adire audio subs or elemental design, another consideration was 4 e12a.22 subs too, so any input would be cool from anyone around.....
i was really learning towards thos e12a subs, but i looove brahmas and i loooove shivas and i loooove w7s hehe
Username: Hydro
Post Number: 88
12"Elemental Designs E12A.22
Voice Coil Diameter:3 inches
XMax: 26.0 mm
F-s: 27.3 Hz
Retail:$295.00
12"Adire Audio Shiva
Voice Coil Diameter:2 inches
XMax: 16.6 mm
F-s: 21 Hz
Retail:$110-125.00
12" JL 12W7
XMax: 29 mm
F-s: 27.2 Hz
Retail:$500-1000.00
The Shivas will hit lower than the E12A.22 and 12W7 but you can bet the E12A.22 and 12W7 can displace alot more air than those Shivas can meaning more SPL.
Username: Hydro
Post Number: 89
Also If I were in your shoes I would go with the 4 E12A.22's for Sound Quality and Spl reasons.
Username: Glasswolf
Post Number: 1027
two 13W7s and two 1000/1 amps
32mm displacement one-way per sub.
Username: Glasswolf
Post Number: 1028
pardon me.
32mm Xmax I meant to say.
shouldn't try to post and watch 24 at the same time
