its really a toss up, if you go with 2 12" they'll be louder but 1 12" or 2 10"s would probably be pretty close to the same.
Hearing your music outside your car just means your car has terrible insulation and you'll loose alot of what would be inside your car.
taylor17
I have 2 10 hx2's and they get "loud" But in my oppinion 12's just have a deeper sound, I would go with the 12's. The only reason I didn't go with 12's is they woudn't fit under the back seat.
