Car amp via dvd player
Username: Sadisticpunisha
can anyone tell me how to rig at 250watt car amp into my home entertainment systom?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6644
not advised.
Username: Carguy
Post Number: 900
Luke, do you watch starwars? Just curious.
For 250W amp, it's not worth it. You'll find cheaper home stereo amps vs trying to convert car amp. If however, you have a nice car amp, then it's possible. I've done it. I find it better than buying one of those all in one subs (built in weak amp).
helps alot thanks
tell me how plz....
Username: Carguy
Post Number: 916
You'll first need to get a 12V power supply from an Electronic store. Try and match the fuses on the amp. You should be able to see it on the amp's case.
Connect the POS to the amp's pos and remote terminals, NEG to the neg terminal.
Attach the rca cable to the amp's rca input and you're done.
Since most car amps are designed for 4ohms, and your home stereos are 8ohms, you're not going to get the rated power. Probably half the rating.
