Trunk Rattling
Username: C12698
Oklahoma
Post Number: 15
If anyone knows anything about a 96 Acura TL, please help. I have 2 12" subs in there. The inside sounds fine, but the outside of the car (the trunk)rattles pretty bad (very annoying to other people) I took the carpet thing off the inside of the trunk lid and put padding in between the cross beam things and the actual trunk lid and it helped a little. But now I think it's the whole trunk lid that is rattling. I can push in and down on it and the rattling is alot quiter. Can I tighten the trunk lid up or anything, or am I just screwed? Any suggestions would be helpful. Thanks, alot!!
Username: Smhuosrktays
Rochester, New York USA
Post Number: 21
Check E-bay for sound deadening materials.
