Best non component tweeters
Username: Sanchez5888
Post Number: 12
I'm thinking about not getting components and just buying the best singles that I can get. I have an 04 civic and It already has factory tweeters on the door that I'm going to replace. What are the best tweeters, no price limit.
Username: Oleg
Santa Monica, CA USA
Post Number: 174
My sister has that car and I have the '01 and I don't see any separate tweeters in any of them. The stock speakers are crap, so spend a little more money and replace the whole set.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6602
best tweeters? money no object?
Rainbow Reference.
second choice, DynAudio's top end tweeters.
Username: Jonathan_f
GA USA
Post Number: 2824
What size are you working with here? Also, do you like a smoother sound (soft domes), or a crisper sound such as metal domes?
Post Number: 19
I'm not sure of the size, It's an 04 civic, and crutchfield and places like that don't have the size. Its a coupe with factory tweeter holes. I'd prefer soft domes, I like the sound better.
