Bronze Member Username: Langless28Post Number: 41 Registered: Dec-04 | ight i got a alpine mrd-m301 and sq and slp are very important together. should i run polk mm2124 or the infinity perfect 12.1 (sry the 2 ohm models of both) i was planning to make a ported box but polk reccomends only sealed. any comments would be appreciated. thanks alot |
Bronze Member Username: Langless28Post Number: 42 Registered: Dec-04 | well i have to correct mymself cus polk doesnt make two ohm svc so i would (if) get a 12" dvc 4 ohm. sry |
Bronze Member Username: Wolfdog22usPost Number: 11 Registered: Dec-04 | http://www.cardomain.com/memberpage/369397/6 I had Polk in my car, sounded good. But Id go for Infinity Kappa Perfect 12. Check the website to see what I have (And putting in). I love Polk components, but as far as Sub, go infinity. |
Bronze Member Username: Langless28Post Number: 43 Registered: Dec-04 | ight thanks but i narrowed it down to the polk mm2124dvc and the kappa perfect 12.1d. i already have the alpine mrd-m301. what type of box enclosure would anyone reccomend. i have right now a pinoeer 12' in a ported box and i like the way it sounds, so will a sealed box sound any diff?? |
Bronze Member Username: Langless28Post Number: 44 Registered: Dec-04 | sry what i mean is will any of the subs i want sound diff in a sealed than ported??? |
