Which subs for these 2 us amps
Username: Heavy_chevy
San diego, Ca Us
i'm stuck between these subs to run for 2 us amps de-3ooo 1.(4)15 JLW3 2.(4)JL13w7 3.(2)kicker solo x 18's going into a chevy extended cab for everyday driving any sugestion please
Username: Iamdisturbed
Vc, Nd
go with the solo xs, u wont regret it, u dont even need two of em but u can get 2 of em if u wanna go def. my one is running way louder then i can handle
Username: Zacdavis~
Post Number: 364
you have 2 us amps de3000's? wow, those amps are nutso powerful, one is plenty.:-)
Username: Jonathan_f
GA USA
Post Number: 2799
Personally, with a US de3000 amp to put on subs, I'd get two 15" or 18" Eclipse Ti Pros.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6579
the 13W7s aren't bad subs.
I dislike the solo X subs.
two 15" or 18" RE triple X, Eclipse Ti or DD 9915 subs would be a better solution.
Username: Erik123456
Arlington, Tx
Post Number: 230
what about ID MAX's i bet that would sound nice
Username: Glasswolf
Post Number: 6583
yes they would indeed
