Jl audio
Username: Ninemode
Atl, Ga
Post Number: 17
i just bought a jl audio 500/1 and was thinking of using a jl audio10w7 any other suggestions on a single 10 inch sub in that caliber
Username: Jmloughrey
Farmington, CT
Post Number: 559
maybe an Adire brahma 10, think you may need a touch more power to get that brahma moving though...
Username: Solacedagony
New Jersey US
Post Number: 152
Brahma, X.X.X, Eclipse, Treo, JL, etc. SQL type subs.
tracy
hi i have the 500/1 with the 10 W7 if you heard them paired together i dont think you will be disapointed but if your more into sound quality try the jl W6 12" there both a very good match
