i have an alpine v12 100 and it has no markings or ratings on the back i was wondering if any one knew the stats or any info on this amp. as well as if it would work with a 15" ma audio sub 800 watts max power thanks
bluntman420
Amplifier Type: Mono RMS Power: 100W x 1 @ 12V THD at 4-Ohm RMS Power: 0.08% RMS Power: 150W x 1 @ 12V Speaker Level Inputs: Yes Preamp Outputs: No Built-In Crossovers: LP Bass Boost: 12 dB Frequency Response: 20-200 Hz Signal to Noise Ratio: 100 dB Fuse Rating: n/a
those are for the mrv-100m.....is that what you wanted?
bluntman420
mrv-100m...is that it?...and if thats it you might wanna get rid of that one and buy another one.
