Noise filters
Username: Xxkmfdmxx
Saint Petersburg, FL USA
Post Number: 113
How good do RCA noise filters work? Will it fix that RPM noise I get from the speakers when I have an amp connected?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6519
hat's caused by a ground loop usually, and not by the RCA cables.
you need to find a better ground point for one of your devices.. often the ehad unit
Username: Glasswolf
Post Number: 6520
*head unit
Username: Xxkmfdmxx
Post Number: 117
Ok, Tried one of those Ground loop isolators yesterday and Not only did it block out the RPM hum, it basically blocked out all sounds leaveing it to sound like crap. The amp is grounded well so I guess I'll try grounding the headunit to something else then. Thanks glass for your help
Username: Carguy
Post Number: 883
Whoa, that's some ground loop isolator.
Username: Xxkmfdmxx
Post Number: 118
lol yeah, Scosche was the make of it. Don't know if its defective or its suppose to be like that.
if your power cables are running next to your RCA's. it'll introduce engine noise in your speakers. check your cable setup.
Username: Xxkmfdmxx
Post Number: 121
The power cables are wired on the right while the RCA's are on the left. So that shouldn't be the problem. I changed the ground wire But For some reason my Amp wasn't working today, It would show power but you hear nothing out of it. So gotta wait a couple days untill my other amp comes in to test the new ground on the headunit.
