How to tell ohms
Username: Robby_
how do i tell the om's of my sub it's not located on the speaker anywhere
thanks
Username: Trojanmanms
well, you could try finding the model number on the back of the speaker and googling it.....that usually works. Sometimes you can even just type in any set of numbers on the back of the speaker in google and it will give you SOMETHING. Make sure you do the numbers in quotes though. Hope you find it.
-Mario
Username: James1115
Ct
Post Number: 45
no thats not how you wanna find ohms! The easiest way is to find a site that breaks it down for you. There are many but here is one. Go to http://jlaudio.com/tutorials/wiring/index.html you should be able to find what your looking for there.
James
Username: Carguy
Post Number: 880
If you need to know your sub's ohms, use a DMM. It'll tell you exactly.
Username: Solacedagony
New Jersey US
Post Number: 147
Yea that's what I would have said, Issac.
Looking at wiring diagrams isn't going to do jack for you, James.
Username: James1115
Ct
Post Number: 46
ohhhhh got ya! read it wrong!
sorry
James
Username: Robby_
so i should use an ohm tester and plug it into to speaker inputs and see what the reading comes out as.
also i have oe other question how do i test the volts coming out of my deck or head unit so i can know what level to set the gain at
thanks
