Boredom and ebay....
Username: Erik123456
Arlington, Tx
Post Number: 235
well its 11:20 and im thinking of buying the eclipse 8454 for 460 total -- is this a good deal, its brand new with 1 yr warranty
or should i just pay my local dealer like 600 for a 3 yr warranty
its the head unit i want, just dont know if i should try to save a couple bucks
Username: Jmloughrey
Farmington, CT
Post Number: 591
www.acaraudio.com
pretty sure i saw it there for a heck of a lot cheaper
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 274
Eric that is a great deck. I am suprised you can find it on the web. Eclipse is pretty picky when it comes to that. As for the price it is up to you. I do know eclipse will not replace it if it is stolen and you purchased it from the web. So if you are afraid it will get stolen, go thru the dealer.
