Adire Brahma sub and Arc Audio amp
Username: 96_caprice_22
Post Number: 21
I was looking at an Arc Audio amp to power an Adire Brahma. 1st is that a good choice or should I go with something else? Their are 2 amps I was lookin at the KAR 900.1 and the 1500 XXK. One of them is 900 watts in a 1 ohm load the other is 900 watts in a 4 ohm load. Which would be better for the sub a 1 ohm load or a 4 ohm load or would it matter since the sub is dual 2 ohm and can be used for both 4 ohm and 1 ohm operation?
Post Number: 22
Would 900 watts be enough power for a brahma or should I go with more?
Username: Slim
St.pete, Florida
Post Number: 89
thats enough becuase the arc amp is probably under rated neways
