Subs?
if you are under a really tight budget what would probably be the best subs to buy not worrying about the watts or amp or anything just by like picking a good name brand or the ones that produce the most bass?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6332
Kicker Comp VR or RE's lower end subs like the RE line.
www.kicker.com
www.reaudio.com
both under $99 each for a 12" and both very good subs..
each will take about 300wRMS per sub
Username: St_john_boy
the cvr's are definetely good boom for a budget, a buddy of mine has had a couple 12s and they sound pretty decent
