Wiring question
Username: St_john_boy
i just recently picked up a kx1200.1 and im not sure if i should wire my 15" L7 in paralell or in series. any help would be appreciated, thanks!
Username: Carguy
Post Number: 838
That'll depend on your subs. Are they 4ohms DVC or 2ohms DVC? The goal of wiring parallel/series is to match your subs to amp's ohm requirement.
Username: Stjohnboy0000
alright, having some screen name issues, lol.
anyway, i have the 4 ohm DVC sub
Username: Carguy
Post Number: 840
I think that amp is 2ohms stable. So if you only have 1 15" L7 sub, then yes wire it in parallel so that you can get 2ohms total (pos to pos and neg to neg on the sub).
Alright, well thanks a lot for the info.
