Setting gain with DMM
Username: Iamduff_87
Michigan America!
Post Number: 266
Ok i have read on the JL audio website that you can set your gains more accuratly by using a DMM and a test tone cd. i was wondering if anyone knows of a chart for MTX Thunder amps so I can see what the voltage would be. If you look at the tutorial on the JL site it has a chart for JL Slash and E series amps. I have a MTX 311d. If anyone knows that would be a lot of help.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6232
generally I use an oscilloscope to accurately set gain, but that JL guide should give you an idea of how to do it if your meter reads "true RMS" values for AC circuits
Help2
Amp does 200wRMS at 2 ohms...so...
200*2=400
square root of 400=20
set your amp to 20 volts
using the same steps on the JL thingie.
Help2
200*2=400
set your amp to 20 volts AC
Username: Glasswolf
Post Number: 6254
there ya go
sorry my answer was brief.
I was getting dragged out the door when I was trying to respond to go look at cabinetry for some remodeling.
Michigan America!
Post Number: 269
oh ok. also the amp says 200wRMS @ 2ohms but thats at 12.5 volts when the car is off
when the car is on i run 14.3-14.4 and is rated at 300wRMS @ 2 ohms at that lvl. should i set my gain at that time ??
Username: Glasswolf
Post Number: 6275
yeah I'd set the gain based at above idle so you get alternator voltage. that way you won't overdrive the system at all when the car is running.
Michigan America!
Post Number: 270
ok cool. so 300*2=600
square root of 600 = 24.5
is the *2 mean take the RMS and x it by the ohm?
Username: Glasswolf
Post Number: 6317
yes RMS wattage multiplied by the impedance.
