Help with speakers
Username: Jmiller
I want to replace all 4 speakers on my 04 Accord EX 4 dr but I'm having problem getting them. I know it uses 6 1/2 in front and I can use adapter plates to use the same side on the rear but when I go to crutchfiel.com nothing I want fits accordind to them. They only sugestion are $200 and $300 components. I wanted to use Polk db650 6 1/2 60RMS all around and which circuit city say will fit and push it with a good 50x4 AMP but crutfeild says that this speakers will not fit.
Any sugestion?
Username: Challenger_ta
i have the same problem with a 93 accord ex 2 dr. i called a honda dealership and spoke to the service mgr. and he said 6 1/2 all around. maybe you could try the same thing.
Username: Jmiller
can somebody sugest some speakers under $200 a pair that will fit my car?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6302
you should forget crutchfield
they overcharge badly. MSRP on everything
I'd look at Infinity Kappas, or Kappa Perfects
the Perfect 6.1 set is $200 NIB on ebay.
the Kappas are considerably less.
CDT Classics are another option, from thezeb.com
even Boston Acoustics or MB Quart
just shop around online. google for the models you want to find.
Username: Glasswolf
Post Number: 6303
challenger, do you have a t/a? what year? which motor? what color is it?
I'm nosey
I have three old mopars sitting here myself.
