Help with line out convertoer
Username: Littleman
OK I KNOW I CANT SPELL IT BUT I RAN IN FROM THE BACK SPEAKERS NOW IM NOT GETTING ANY SOUND TO MY SUBS i mean theres bass every now and then but nothin like when i ran it off the hu in my last car only hear it once and a while but what im asking is could i have the rca mixed up or is it nit grounded well please help
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6425
so you ran an LOC from your rear speakers, and connected that LOC to an amp for subs, but you're not getting any bass.
Most likely the LOC isn't the right one for that system, or something isn't set right.
it could be a lot of things really.
Username: Littleman
i bought it from circuit city they said it would work i got 2 1000 lanzar 12s and a 500 watt mtx amp what im asking is could i have the loc hooked up wrong cause im not geting any noise out of the subs but a little thump here and there thats what i meant i was tired last night
Username: Glasswolf
Post Number: 6460
CC is notorious for not knowing what they're doing.
trust me on that one.
what make and model is the car, and what year?
is this a premium factory system, or just a standard non-amplified sort of factory radio?
If this is a premium or amplified system, you need a special module to adapt and tap into the system to get a clean line level signal.
let me know so I can advise from there.
Username: Littleman
its just a facotry non amoed system and the car is a 1998 ford tarus i owuld of out a after market cd player in it but the dash kit cost around 80$
Username: Littleman
Muskegon, Michigan
or could you just tell me how to hook one up so i cann see if i did it right
Username: Glasswolf
Post Number: 6476
you just wire the LOC to the rear speaker wires.
it should have had directions with it.
Username: Littleman
Muskegon, Michigan
ok well i think its the ground see the loc had a wire that say for a ground ststem run this wire with ground ciuld that be the problem
Username: Glasswolf
Post Number: 6484
did you ground it?
if you didn't then yeah that'd pretty much be the problem.
Username: Littleman
Muskegon, Michigan
Post Number: 7
ok will try if that dont work will take it to tech audio in grand haven and see what they can do
Username: Glasswolf
Post Number: 6493
haha
grand haven. that's about 45 minutes from me if I recall. lol
I wish we had more high end shops around here. I have to go to Saginaw or GR to find much in the way of decent shops. Ah well. off to ann arbor Friday for the day.
get to look at toys there if I get the time.
Username: Littleman
Muskegon, Michigan
Post Number: 8
do you have a aim name so i can chat with yay for a min got some queation i want some quick reposces to
Username: Glasswolf
Post Number: 6494
I try to avoid sharing that stuff on forums, because I end up with a hundred people adding me, and no free time or privacy at that point.
nothing personal.
it's like putting e-mail addresses in open forums. it invites a ton of unsolicited mail.
