Like
Blown subs
Username: Munkyjojo
Winamac, Indiana
Post Number: 63
is there any way i can fix blown subs. from what you can see nothing is broke, just the subs doesn't produce any bass and it sounds like crap.
Username: Carguy
Post Number: 796
Everything can be fixed. The question is, is it worth getting fixed? Sometimes the labour costs more than the actual product.
Username: Jmloughrey
Farmington, CT
Post Number: 482
i'd say 95% of the time its easier and costs about the same to just get the new product, a sub is a pretty complex thing to most people so what you see as to be a little problem in actuality its a bigger pain in the butt to fix...take it to a local audioshop, usually one of there techs will check the sub out and tell you what the problem is if you throw him like 5 bucks for lunch or something
Facebook
Shop Related Deals
Directory
