If I run this...will i need one or 2 caps?
Calvin D
Ok, i'll be running:
501bd amp - 638W RMS
Type R 12" Sub - 300W+ RMS
Alpine v12 4 channel amp - 50-75W RMS x 4
MB Quart 6.5" coaxials - 50W RMS
MB Quart 6x9 coaxials - 60W RMS
Also I'd like to know what anyone thinks of this set up and if they think it'll pound.
Thanks.
Username: Tlo211
Post Number: 19
Looks good except that bd501 is too much power for 1 12" type R... I'd suggest gettin a Kicker 12" L7 for $190 from www.infinitecaraudio.com and a build urself a sealed box.
Username: Zen936
Post Number: 48
Alpine 4 channel and the MB Quarts are cool.
Either the Solo Barics, CompVR or Kappa Perfect would complement it well. Man that's gonna be loud!
Username: Glasswolf
Post Number: 981
you don't need any capacitors.
what you'll need is a high output alternator.
