Okay, capacitor questions to end them all!
Username: Danny525
Post Number: 10
ok, my 88 mustang , 4 banger, has 400 rms running 2 infinity 1230's. The lights in the car pulse to the woofers, so is a capacitor gonna fix that? the car starts right up, its not getting drained to the point that its dimming. It does it right off the start. And if i need a capacitor, do you need to charge it or what?
Username: Carguy
Post Number: 976
If you have 1988 Mustang, then it probably has 65A alternator. Most older cars have very small ones. So 65A x 12V = 780W. Now you will have to subtract heater/lights/radio/wiper etc from that total to see what's left for the amp.
At 400W rms, you're probably pushing it too hard. To really fix your lights dimming problem, you will have to get HO alternator. The good news is, since you have a popular car model, you should be able to find a HO alternator fairly cheap. A capacitor only stores energy, so if the alternator's not supplying it, it'll start taking it from the battery. And as you know, with batteries, if the alternator can't supply power, it'll die out eventually.
However, a capacitor will help with voltage rails. Caps are able to supply the stored energy to the amp at a much faster rate, thus giving you tighter bass.
Don't ignore the dimming lights warning. If you do, not only will you lose alternator/battery but also your car's electrical system.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7045
http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
Username: Glasswolf
Post Number: 7046
also consider replacing the following three cables with larger gauge, new cable:
-alternator to battery
-battery to chassis
-motor to chassis
Username: Aaaavv
i am about to have hooked up two jl audio w7 10's and two 500/1 jl amps with a 300/4 channel jl amp on my door speakers aand a 5 fared capacitor. i have a duralast battery with a cold crank of 840, and a factory alternator. my vehicle is a 2002 super crew f-150. the guy at the stereo shop said with a 5 fared capacitor i wont have any issues. what do u guys think. am i still gonna need a high out put alternator.
my second question was regardind the yellow top baterries or optima. ive been hearing alot about them, whats so special about them, and where can i get one. would auto zone carry them
Username: Glasswolf
Post Number: 7084
1: stop hijacking other peoples' threads.
2: stop asking the same damned thing over and over and over.
3: the guy at the stereo shop is an idiot. I feel I'm more than qualified to state that from what he told you, and my own credentials.
4: regarding batteries:
http://www.wickedcases.com/caraudio/batteries.html
http://www.optimabatteries.com/
