What do you recommend
Username: Corn
I am looking for a amp and 2 subs at around $500 what brand and what size of amp and subs do you recommend
Username: Corn
i already have 4 pioneer 4-way speakers 6" X 8" 240 W. would you recommend hooking up an amp to those speakers as well.
Username: Glasswolf
Post Number: 946
(2) 12" Elemental Designs subs
(1) JBL BP600.1 amplifier
look at JBL's 4 channel amps for the 6x8 speakers.
Username: Corn
where is the best place to get those and what is the price range. What box should i use for those subs
Username: Hydro
Post Number: 74
K-Series 12:$135.00
O-Series 12:$195.00
A-Series 12:$295.00
Sealed box If you dont have much space to work with.
Ported/Vented box If you have Extra Space(Ported Enclosures do not need as much power as a Sealed Enclosure)
http://www.edesignaudio.com/ep2/aseries.htm
Username: Glasswolf
Post Number: 952
the amp is from www.etronics.com
$210
Username: Golflover123
you can get the A series for $210 and the amp for 179 as of now on e-bay http://cgi.aol.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3074288098&categor http://cgi.aol.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3073586904&category=18797 y=18803 glasswolf do you think the jbl amp is better than the kicker?
Username: Glasswolf
Post Number: 963
Kicker's 600W amp is better, but also costs at least half again more.
I didn't mention ebay because ebay isn't what you'd call an official dealer.
it's a try at your own risk sort of deal.
Username: Corn
i found a set of 2 JBL GT1241D Grand Touring Series
12" Dual Voice Coil Subwoofer for $135 si this a good deal and would the amp that was mentioned earlier work good with them. what is the sound quality of these.
Username: Corn
I have a friend that uses a 900 W or 1 kW amp to power two 10" subs what is the difference in the watts from 600 to 1000. i am just getting into car stereos so i know a little but not alot. what is an ohm.
Username: Corn
is this a good amp KICKER KX600.1 600W Amplifier i found it at Jungle discount for $260 this is the same place i found the 2 subs. would they work good together do you think.
Username: Corn
Post Number: 7
has anyone heard anything bad about jungle discount? do you think they would be a reliable place to buy parts? sorry about all the questions just looking to get opinons in order to maximize the quality of my stereo sound.
never heard of it? what is there site address?>
Iori
What is a good 4 channel amp for under $200(ebay) that's rated at at least 150 rms per channel
Username: Corn
Post Number: 8
would this amp work godd for my pioneer 4 way speakers KICKER KX800.4 800W 4 Channel Car Amplifier if i were to run all of this would my 2000 ford contour be able to handle all of the extra watts.
Username: Glasswolf
Post Number: 964
lori: no such thing.
150w x 4 @ 4 Ohms is a HUGE amplifier for class-AB, and there are very few even made that really put out that much power. They are also very expensive.
Plenty of 4 channel amps in the 50-75W x 4 range.
Username: Glasswolf
Post Number: 966
You might be able to find a Kicker KX800.4 for around $250 US, which is 100W x 4.
