Speaker helpp
dman
Hey, I have 6.5 pioneers in the front of my car (stratus) and it has a rear fill for 6x9's so I replaced them with pioneers. But I think I blew one so im going to take them out, what would be the best thing to do....replace them with another set of 6x9's or put 6.5s or get tweeters or even a amp?
Username: Carguy
Post Number: 822
Hey dman, the first question is how did you blow one of them? Do you have external amp?
It's not that easy blowing up a speaker. Most can take some abuse. Anyhow, you can replace it with stronger 6x9 speakers.
External amp will only enhance the sound so if you can do it.
You don't want to place tweeters at the back. Front is your best location.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6246
for rear speakers I'd just stick to 6x9s.. add a sub if you want some bass response
