Speaker question
Username: Spanky
Post Number: 81
ok i dont wanna sound like a newb but i am..when you power front componets how many actual watts do you need so you can increase the volume and notice a difference as if u werent powering them with an amp... (so the bass doesnt really drown out the music)
Username: Mr_kebo
Albertville, Al USA
Post Number: 87
Most decent componet sets can handle 75+ watts, So just check the specs on your set of componets and power then to the max :D
Help2
Are you powering them with an amp?
to gain a difference over the internal amp of a HU youll need at least 30wRMS
based on your other post...
Id go with at least 60wRMS if not more.
Username: Spanky
Post Number: 83
im thinking of getting the 6.5 perfects what amp would u reccomend for those componets?
Username: Spanky
Post Number: 84
hello???
Username: Spanky
Post Number: 85
bump....
