Switching 8 and 2 ohm
Username: Langless28
Post Number: 22
would it be benifitable to use two relays to switch two subs form a 2 to 8 ohm load at the amp. i found simple plans at a credible web site. the change would occur by activating a switch.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6219
all it'dd do is change power to the subs. You can do the same thing by turning down the volume.
Username: Glasswolf
Post Number: 6220
ps, the word ya wanted was 'beneficial.'
Help2
I like his version better...
ThatGuyYouKnow
is that george bush?
