CDT-CL62i/20, Pros & Cons...
Username: Brian_hunter
Tacoma, Washington United States
Post Number: 16
I'm thinking about getting a pair of CDT-CL62i/20 but I want to know what's good & bad about them. For your information the CDTs would have two 8 or 10 inch subs to back them up in a 1994 Toyota Celica Coup (2 doors 4 seats but back seats are small) & the CDT 6.5 woofer would go in the stock location in the doors.
Specs:
Model # CL-62i/20
-Stainless Steel Top and Bottom Plates
-New Elliptic SatNet 560i 4th order Crossover
-Compound Curve Woofer Cones
-Powder Coated Steel Baskets
-Carbon Treated Woofers
-3/4" soft dome tweeter
-Butyl Surrounds
-(New) 3/4² Silk Tweeter
-Power handling:150Watt RMS
-Freq resp:55-20kHz
-Sensitive:92.3 dB.
-Dept:2 7/8²
Username: Jonathan_f
GA USA
Post Number: 2704
Not really any cons to mention. They're built very well and have excellent sound quality. It's a subjective matter, they have excellent sound quality and tonal balance, they're not harsh, they're not overpoweringly loud or "fat" sounding either. However, that doesn't mean you'll like them the best out of your options, you'll just have to go listen to speakers and see what your preference is.
