4ohm DVC = 4ohm total?
Username: Jwbulger79
Florida
Post Number: 81
is it possible to run a DVC sub with 4ohm per VC to a total of 4ohm?
can you run it in series and parallel to get 4ohm or does a 4ohm per coil DVC only run 2ohms and 8ohms?
Help2
No can do.
only 2 or 8 ohms
Username: Koz1031
Monticello, In United states
Post Number: 308
Can't u run a 2 channel amp, and run 1 channel to each voice coil?
Username: Businessboy
Post Number: 88
u could - that would be running 8 ohms then right?
just run at 2 if yours amps stable. - more power!!! :-)
