Jl w6v2 w7 question
Username: Erik123456
Arlington, Tx
Post Number: 212
is the w7 markedly better than the w6v2?
im toying with the idea of gettin a 8w7 in the high output enclosure or sealed enclosure that jl has
will the sealed enclosure still be fairly loud? its a cool option in my mind bc it takes up hardly any trunk space and runs off about 300 watts with supposedly great sound and fairly good spl
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 232
IMO the W7 is a better speaker. I am also a fan of sealed boxes. It won't be quiet as loud, but more than likely it will be loud enough. So I would give it a try and if you don't like it ask them if you can listen to the other box. Most stereo places won't mind letting you swap out the box.
