Bronze Member Username: Eric77Post Number: 22 Registered: Nov-04 | I got everything ready for my system and I am having it installed saturday, but I dont have an amp kit yet. I have a nine.1 and I guess I am going to get a 4 awg amp kit. I know a guy locally that will get me any name brand stuff for close to cost so that really helps. What should I get? I was looking at a stinger kit, which I heard was pretty good. Is stinger all its cracked up to be? BTW, im looking to spend around 40. Also, I know knuconcepts is good but since I need it by saturday I dont think that will work. Thanks. Eric |
Bronze Member Username: Eric77Post Number: 24 Registered: Nov-04 | BUMP! I need to order tonight so any advice you have to offer now would be greatly appreciated. Thanks. |
thatsthekid Unregistered guest | go to walmart. most amp kits are the same. you can get a cheap one for half to a third of the cost as the "big" brands. |
Silver Member Username: JmloughreyFarmington, CT Post Number: 455 Registered: Jul-04 | www.knukonceptz.com great wiring kits |
Bronze Member Username: Addicted2bassMiami, FLORIDA USA Post Number: 42 Registered: Nov-04 | stinger is good, thats what kit i use. I dont think its the best but it good to me. |
Bronze Member Username: Eric77Post Number: 25 Registered: Nov-04 | Basslova, how much did you pay for yours? Also, what ga do u have and how many watts is your system. Thanks. |
ThatGuyYouKnow Unregistered guest | I have to say Knu and with good reason. Lets take a RF amp kit for example, they'r wires are so hard they will make your fingers bleed if you try to twist them in a spiral.(personal expriance). Once I got a hold of Knu amp kit, i was wow'd on the flexablity of the wire, more strains of copper (espacally in the sub wires) I still have my old Knu amp kit and the wires are still soft and flexable, they give you ample wire for future voice coil configs. I have never pricked a finger with this wiring kit. Anyone like getting there fingers pricked? About to purchase another amp kit from them soon. why the big rush may I ask? |
Bronze Member Username: Eric77Post Number: 26 Registered: Nov-04 | I already have an appointment to have everything installed. I guess im just impatient. lol. I am getting a monster cable 4 awg kit tomorrow for about 45 bucks, so it will end up being about 10 bucks more than the knu conceptz would have been, but oh well. Besides, I hav heard good things about monster cable. |
ThatGuyYouKnow Unregistered guest | Yes monster cabe is really nice, its what I use for home audio. But man one cable cost me $25, It was a earphone jack into L&R RCA plugs. |
Silver Member Username: Koz1031Monticello, In United states Post Number: 307 Registered: Jul-04 | radio shack wire is allright also. their rca jacks are little pricy but still good. I can get 4 gauge here for about $1 a foot. not all that bad. |
Bronze Member Username: Flyfishin4troutPark City, UT USA Post Number: 36 Registered: Nov-04 | You can get great deals on www.cardomain.com on stinger kits. They have some high perf ones that are great. You can go to www.hifisoundconnection.com and get their prices and use them on cardomians web site to get a price break. The reason that you wouldnt want to order from hifi is because they will deliver eventually but I hate to wait. Here is an example. http://www.hifisoundconnection.com/productcategory_detail.php?itm_id=42&pagefrom =category&product=id that is a great deal on that. Almost cost |
