Amp for my 2 subs
Abyss_Omega
Hi my old Mtx amp just crapped out for some reason. It was a MTX RT2400X. I just bought two MTX MXS1204. I was wondering would the best amp to buy be the MTX MXA8001 since they are kinda made to go together. Or should I get a different amp? Any imput would be welcomed thanks
Username: Araknid
Post Number: 38
well we need to know about the subs.
Username: Xxkmfdmxx
Saint Petersburg, FL USA
Post Number: 95
Mike, He mentioned the subs, MTX MXS1204. Their 12".
Username: Xxkmfdmxx
Post Number: 96
More info about em
Cone Material Expanded Poly
Frequency Response 29 - 150 Hz
Impedance 4 Ohms
Magnet Weight 204.1 g
Mounting Depth 7.2"
Ported Box Volume 1.75 Cu. Ft.
Power Handling Max 400 Watts
Power Handling Nominal 200 Watts
Product Warranty 1 Year Parts & Labour
Recommended For Band Pass Yes
Recommended For Ported Yes
Recommended For Sealed Yes
Sealed Box Volume 1.25 Cu. Ft.
Sensitivity 85.2dB
Surround Material Rubber
Voice Coil Size 2"
Woofer Size 12"
Since your too lazy to look em up lol. I cant help ya though Abyss
Abyss_Omega
thanks anyways mdfmk
