Anonymous | i have a 95 chevy ext cab Z71, and i want a system that will do 145db+. what would i need to get in order to do this? i already have a bp1200.1 (from my old system) and i am willing to take my back seat out to put in subs. what subs should i get? will 1200w be enough to get 145db? i think the resonance frequency is between 47-51hz. |
Anonymous | Pick you up 2 12" RE X.X.X subs |
Anonymous | what are re x.x.x. subs? what is the brand |
Bronze Member Username: LoudonPost Number: 72 Registered: Jun-04 | Reasonant Engineering |
Silver Member Username: DecdeCanada Post Number: 272 Registered: Sep-04 | www.reaudio.com These are some amazing subs. Not cheap, but worth the money. U can also check out www.adireaudio.com for brahmas. Both are very good subs. If your an spl fanatic, and you don't give a rat's a$s about sq, check out the Re Mt's. Trust me, they'll turn your world up side down . |
Bronze Member Username: Flyfishin4troutPark City, UT USA Post Number: 31 Registered: Nov-04 | Where can you buy the RE x.x.x? |
Silver Member Username: DecdeCanada Post Number: 275 Registered: Sep-04 | www.reaudio.com Call them and they will either ship you one or tell you the closest retailer to your place |
taylor17 Unregistered guest | What if you can only fit 10's. Is it still posable to hit 145. I have a 98 extended cab z71 but I like the back seat What 2 10's can I go with. 145 to 150 is my goal. |
Gold Member Username: Its_bacon12Hfl, Ny Usa Post Number: 1175 Registered: Dec-03 | try some shocker sigs...haha those will destroy your car |
Sucubus Unregistered guest | Theyre freakin expensive, but crazy loud. New ones got neo motors on em too.. just as powerful, but lighter! |
Gold Member Username: Its_bacon12Hfl, Ny Usa Post Number: 1176 Registered: Dec-03 | yep i saw that on icix haha i think they go for a grand or so a piece? not sure where u can get them tho... instead of 80 lb 15" its only like 60 haha |
