Teach me what you know about Elemental Design subs
Username: Crazy3rdgen
Long Neck, Delaware U.s
Post Number: 68
If you own an Ed sub or know somone who does, what do you think of them and how they perform? spl,sq..
ENJOI 150db
yea hey people i just bought four elemental design Kv.2`s let me know if they are good, bad and what not even though its too late cuz i bought them, haha i have faith in E.d
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1182
i have a pair of 11kv.2s in a massively huge porrted box tuned to 29 Hz with 250w rms each one and wow...they are pretty darn loud i have abut 141.3 from them at dash and like 157 something at the port
freakin loud especially for 10s heh
Help2
I have a 13Kv2 on a NINe 2.
IMO a 13Kv2 is a shiva with better SQ, and more SPL.
Some people will probably disagree with that,
but more than likely they havent heard a 13Kv2.
Ive heard both.
The eD sub is also more transparent than any sub
Ive heard in the same class.
Another good thing...is they preform better
in a small box than most subs in the same class.
Considering you get a free 3 year warranty...
free help with box design and wiring instantly
using the eD Live system(daytime hours)
and a price tag under 140 bucks shipped(115 for the 11Kv2, 125 for the 13Kv2, 135 for the 16Kv2..all shipped prices)
no B stock crap...no shady eBay sellers...
This is manufacturer direct.
You can even call up the owner and talk to him
personally if you want.
that being said...
I dont think theres a better deal on the market.
They will surprise the crap out of you.
Hfl, Ny Usa
Post Number: 1184
agreed :-)
and well put
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 298
whats the website for the ed's?
Help2
www.edesignaudio.com
Username: Udai
How would you guys compare the IDQ 10V.2 D4 to the same class sub for ED
Im getting my car soon and i want to know which 1 has better sq. Im looking for about 500 watts rms total. Also whats the diff between a duah 2 ohm voice coil and a dual 4 ohm
Help2
The difference between dual 2 and dual 4
is just wiring options.
for instance...if your amp
is stable down to 2 ohms x1
get the dual 4 version
if it is stable at its highest power
to either 1 or 4 ohms x1, get the dual 2
version
IMO, ID subs are a lil better than eDs, but they
are more expensive...(bout 35-40 bucks on average)
Either way, good choice.
Post Number: 299
would any of you say that an eD sub is better than a JLW3D4(not the V2) 12". I have a JL W3 but i want something with a little more "umph". I was lookin at IDQ v.2 or an eD Kv13 if that is the right name. Could anyone tell me? Also is that a 12 inch sub?
Help2
the eD 13Kv2 is a 12" sub, yes.
they refer to it as a 13" because the
cone area is closer to a 13" than a 12"
it will still fit in a 12" sub hole.
The IDQ and the eD are quite similar.
youd probably enjoy either one.
the eD has a little more power handling,
and a lower pricetag.
the IDQ will be have a little meatier sound
and will give you a little more "listen to ME" attitude,
as opposed to the more transparent sound of the eD.
Post Number: 300
thakns Help2, finally someone answered a question of mine after 2 days. so you are saying that the IDQ will, in a sense, hit harder than the eD? Im just trying to get all the info on the subs as I can before I buy one. I already made the mistake of not doing that.
Help2
hard to say really...
depends on the box...the car...the power..
but in my esperience,
the ID will be louder.
although I got my eD for 80 bucks...(pre-order baby!)
Post Number: 301
well i'll be pushing it with a P3001 which has closer to 400 rms than 300. I have a 2.5 cu.ft. slot ported box. I think Fishy said that it was tuned to about 25 hz. Thanks for your help.
Post Number: 302
o yeah im putting it all in my 94 chevy ext. cab silverado. i have my box and JL W3 on the back seat behind the driver seat firing into the back of the seat.
Username: Udai
thanks for the help "help2". I also had a few more questions: will this amp http://www.sonicelectronix.com/viewitem.php?id=360
Hifonics BX1500D Brutus Class-D
push these subs Id12 v.2 d2 /d4 (dual 2/4 ohm)
or IDQ10 v.2 d2/d4
the reason i mentioned the 10s are because i want to save space and I heard teh sound quality is much better. Im sorta looking for the type of sound that you get when you hit your wall with the bottom of your fist. (clean + loud sorta)
If that wouldnt work can you mention a 2 sub/ amp setup that would?
Help2
I would recommend the subs...either set really...
might as well go for the 10s because of the
size constraints you mentioned.
but that amp is a lil too big.
look at this one...
http://www.sonicelectronix.com/viewitem.php?id=533
less power...yes...but better quality.
probably does closer to 700wRMS @2 ohms.
so...get a pair of the dual 2 ohm version
IDQ10s and wire em in series/parallel.
what kind of box were you planning on?
chris22
I really like the ed stuff.
I had a 13Kv.2 and a NINe.2 installed at their shop in my truck. They did a freaking awesome job. Friends still can't believe what i spent.
ENJOI 150db
Damn guys thanks for all the inputs, so basically are ya`ll sayin my four 13kv.2s all properly powered will be loud??? haha i hope so they will def be louder then those damn punch He`s i had and i hit 150.1 with them woo hoo!!!
Help2
4 13Kv2s with 500wRMS on each in a ported box tuned to the resonant freq in your car...
one word...
scary.
definately not daily driver material though. :-)
Username: Udai
Heh thats what im looking for.. daily driver (keeping my hearing tho)
Well i dont know the specs on the trunk space in the scion TC hatch, people seem to fit 12s just fine, i dunno.. what do you think? If you post your email ill send you some pics +other info. And are you sure about that kicker amp.. ive heard alota good stuff about that hifonics products(im just judging by the kicker subs, i hate them..)
The type of enclosure im looking for is completely custom. Its a sort of a mold into the 2 corners where the rear seat + side walls join in the trunk.
Help2
Kicker makes better amps than Hifonics...
Youll have way too much power on tap if you
use a 1500w amp anyhow.
You can run the hifonics at 4 ohms(500wRMSx1)
and get dual 4 ohm subs instead,
if you really want to go with hifonics...
In that case you could get a BX500D
with the dual 4 ohm subs
and end up with the same power.
But Id go with the kicker amp and the dual 2 ohm subs.
600wRMS will be overpowering, but not a level
which youd have to worry about.
Plus the Kicker amp is better quality.
Remember...I dont especially like kicker subs either...
as far as the enclosure...
I was curious as to whether you were going ported
or sealed, in regards to the sound you were going for.
Im sure youll be able to fit either one your car,
especially if youre having it custom built
Username: Udai
Im all about sound quality so i assume a sealed enclosure will work best. Give me your email and ill send you a quick pic to give you a general idea of the way i want it to look (and i guess ill go with that amp, thx :D)
heres a pic with some 10s (not the type of box/ setup i want.. but a general idea)
http://www.cardomain.com/memberpage/731217
this next link has a few shots of the trunk
http://www.cardomain.com/memberpage/638714/3
i read this somewhere:
Trunk Space [cu ft.] 12.8
Username: Udai
Ok, I talked to another car stereo guy today and he explains this to me. The speakers I am interested in (W7, IDMax, Brahma's, X.X.X, H2), all 10"s, are huge excursion speakers, they are best used for low Lil John Base, R&B. For me, since I likey the fast and upbeat Techno, long excursion is not the key
^ i read this post a second ago and it sorta applies to me. My friend has 2 12w3's powered by a jl 1000.1 amp
I want very clean/ loud bass (not too deep tho)
like i said earlier, the type of noise you get when you pound a wall with the bottom of your fist. Would those id subs be the right sub for this or not? Sorry about all teh questions
Username: Udai
^ i read this post a second ago and it sorta applies to me. My friend has 2 12w3's powered by a jl 1000.1 amp and when turned up his system sounds great. I want very clean/ loud bass (not too deep tho, i want it like his)
Username: Udai
Post Number: 7
woops, cant edit ;x
Help2
Looks like youve got plenty of room...
You can host pics on this site
if youve got no other way to do it...
But Im giving my e-mail on here...
no need for my mail box to be flooded with
questions...
ya know :-)
Help2
Missed your last post dude...
well...to be honest..
If youre willing to shell out the cash...
the IDMax would be a better option.
Id pick the IDMax for your application...because
they sound phenominal in lower power
applications compared to the w7 trip X and Brahma
the Brahma and Trip X's are a a little more power hungry,
although they will probably get louder.
and the w7 is priced way too high.
IMO...for the sound your looking for...
get either the 2 IDQs ot 1 IDMax.
Powering either with the kicker amp I recommended.
Youll be more than happy.
Username: Udai
Post Number: 8
I see ;p
I plan to spend around 600 bucks or so on just the amp / subs. Do you think id need to get a new headunit? The stock hu powers 6 speakers i believe, stock @ 160 watts. Im sure ill need that extra output thingy i hear so much about on stock hus
heres another pic of the look im going for. But instead of mounting the sub on the side its going to be in the top right and left corners w/ a smaller enclosurei supposeUpload
