Alpine Type R's
type r
I have 2 10" Type R's in a sealed box .90 cu.ft. per sub crossed over @ 80hz off a Kicker KX550.3
and it seems that I am getting too much of the low notes and not enough punch. Any suggestions? Oh ya the subs are 2ohm+2ohm, so I am running a 2ohm Load. Thanks
Username: Hiphopanonymous
Post Number: 169
I was there too. I have type r 12's. i built a new larger ported box for them and now they pound. I tried a larger sealed box too and they were deep and loud.
Username: Wojopro
Post Number: 30
Way too little of air space.
Sucubus
Actually....the box is too big...
try .6-.7cf per sub.
you can just add chunks of wood until it
sounds the way you want...then glue em down
Username: Wojopro
Post Number: 38
Oh, 10 inch. Sorry bout that. Its recommended to be between 5.5 to .8cf. Sorry about the confusion. Looked up the wrong stats on it! =)
