Grounding
I know everyone recommend thats you ground as close to the amp as possible. What are the disadvantages of running the ground back to the battery. What i was goin to do was run a 1/0ga to the back and use a distro block to get my 2 grounds. Would that cause any problems.
Username: Squanto
No, No Usa
Post Number: 48
youd be better off grounding it in the trunk. the longer the ground, the more power you lose.
Username: Deathshadow
Post Number: 339
That and also you have a better chance of introducing noise into the system.
