Music out of sub
i just bought a sub and i noticed that i could hear not only the bass but very softly the rest of the music playing from my sub.
i played with the fading and balance of my speakers and my sub only works when i have my rear right speaker playing.
wtf, is this right, have they wired my sub wrong and if so how do i fixed it and will it Sound beta / hit harder?
Username: Mr_kebo
Albertville, Al USA
Post Number: 79
Check your amp(s) to make sure they're on a low pass filter(low) or off and not on high pass (high)
What kind of crossover are you using?
Is it one built in the amp?
Some low quality crossovers let by some of the frequencies that you are trying to block to the subs.
yer i think its just a built in crossover in my clarion amp that they are using coz i got it installed by a shop as i am not 2 familiar with wiring.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1166
go back and tell them to set the low pass xover to 20-80 Hertz
they will know what to do...
and you wont hear the music anymore
well i looked at my amp and the xover was set to off so i turned it onto low and that seemed to fix the problem, was this ok to do, it wont damage the sub/amp or anythin??
