Can these subs handle the power?
Username: Amiricle
Post Number: 12
Hey want to buy 2 infinfty Kappa Perfect 12DVQ
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12DVQ' &Ser=KPE&Cat=SUB
They do 400RMS each, the amp i want to use is the MTX 6500D, which puts out:
500 watts x 1 at 2 ohms
775 watts x 1 RMS dynamic power
My question is, will the infinty subs bo ok with the extra power? I read something about not turning up the volume all the way, but how do i know when the volume is too high? Thanks
Username: Amiricle
Post Number: 13
i am wiring them so they are at 2ohms each
Username: Carguy
Post Number: 688
Hey Amir, as long as you use self control, it'll be fine. The problem with most HU is that near the top end of volume control, they distort more than they produce sound. So it's not a good idea to max out.
Just set your gain level correctly.
Username: Amiricle
Post Number: 14
thanks
