More ohms doesn't mean more bass right?
Username: Sofa_king_hot
OHMs just are the resistance of the electrical flow and they don't affect the bass right?
Username: Jordan02
Winter Haven, Florida U.S.
Yea Ohms has nothing to do with bass Ohms determine how you wire your subs
Username: Eric77
Post Number: 14
True, although the lower ohms your amp is wired for the more power therefore more bass. That is as long as the amp is stable at that level.
i.e dont run a 2 0hm stable amp at .5 ohm.
You are correct...the ohm rating on the speaker has nothing to do with bass output, it is just a measurement of electrical resistance on the circuit applied to the amp.
