Dumba** move!
Username: Ginuwinepz
Post Number: 20
Hey...i was recently rewiring my sub for 2 ohms, because the people that installed it wired it for 1 ohm and it was overheating my amp....well i was putting it back in the box, and my screw driver slipped and stabbed a hole in the cone!! i have absolutly no warranty on the sub or anything at all, is there anything i can do to fix it or just live with the hole there? if you were wondering the sub is a 15" Kicker Comp thanks for the help!
Username: Zacdavis~
Post Number: 300
cone or surround?
Username: Dnizzle
Raleigh, NC USA
how can u wire a 1 ohm sub to 2 ohms?
JB Weld
Username: Araknid
Post Number: 31
the outer edge?
Username: Araknid
Post Number: 32
if it was the outer edge and its made of rubber then u can melt it with a lighter and then move it together and bind it wit super glue. ive done it before
Username: Xxkmfdmxx
Saint Petersburg, FL USA
Post Number: 85
I did the same thing the other day, Right on the very tip of the cone. Any ideas on how to repair it? A friend of mine told me to put nail polish on it, But I don't see how that would fix it. The hole is about half a inch in length. The hole doesnt seem to be effecting the sound quality of it though.
Username: Zacdavis~
Post Number: 304
hey guys, forget what you heard, i've been reconing woofers for years, use 100% silicone. super glue and nail polish arent very flexible are they?, use common sense when workin on this stuff.
Username: Sploosh56
Ohio
Post Number: 443
yea use silicone. i tried super glue once just to experiment to see what would work best and it ate away the plastic cone rather than repair it. silcone has always been the best for me.
