When Bass Hits Hard, Subwoofer Amplifier Light Dims and Components do not play until bass calms ... What Can Be The Problem ???
Username: Maxkilla
Malta
Post Number: 132
I have a problem when i play bass at high volume the components don't play music. Its like they don't have enough power to play and bass takes over all. What can be the Problem ?
fe-fi-fark-u
Power wire Gauge?
total wRMS?
alt?
Username: Joe718
Brooklyn, NY
Post Number: 272
U need a way bigger alternator. use this site to find one that fits the make of your car http://www.4alterstart.com/
Username: Maxkilla
Malta
Post Number: 133
mmm when the car is idle it does this aswell.
Amplifiers Boss Pd-4000 1200Watts RMS, Hifonics Zeus ZX4000 - 200 RMS
Speakers - Infinity Kappa Perfect 6.1
Subwoofer - Power Aqoustik Mofo 12" in Ported custom Box
Pd-4000 - 4 guage Directed wire
Hifonics - 8 guage wire
Battery - Exide Maxima 9000
Alternator - Stock 60Amps
Username: Solacedagony
New Jersey US
Post Number: 107
Definately a high output alternator.
Username: Maxkilla
Malta
Post Number: 138
Would you change something else ? Is this a nice car audio setup in your opinion ?
