Subs for rock?
Username: Araknid
Post Number: 33
what would be best for fast beat slipknot type music A 10 or 8? because they respond quicker?
but i also like to listen to hard hitting rap music so what would u recomend?
Also is it possible to have say a 10 and 15 hooked up at the same and have a switch to turn each one on or off depending on what type of music?
Username: Mr_kebo
Albertville, Al USA
Post Number: 72
Honestly now days i dont think the response is that much difference because of the advances in motor technology. You could go with a 12 and be ok. To anwser your other question yea it would be possible. The way i would prolly do it would be to hook a switch to the remote line for each amp.
GodDammit
Alpine R types provide a good balance between SPL and SQ, and sound good, shine even, when listening to trash metal type of music. I have a pair of 12's myself.
Username: Decde
Post Number: 263
What hertz are they?
